Configures a user-defined protocol filter.
| filter | Configures a protocol filter. |
| filter_name | Specifies a protocol filter name. |
| add | Specifies that you add a protocol. |
| delete | Specifies that you delete a protocol. |
| etype | Specifies an ethertype protocol. |
| llc | Specifies LLC protocol. |
| snap | Specifies SNAP protocol. |
| hex | Specifies a four-digit
hexadecimal number between 0 and FFFF that represents:
N/A.
Supported protocol types include:
A maximum of 16 customized protocol filters can be active at a time.
The protocol filter must already exist before you can use this command. Use the create protocol command to create the protocol filter.
Protocol-based VLAN for Etype from 0x0000 to 0x05ff are not classifying as per filter. When traffic arrive with these Etypes, it is classifed to native VLAN rather protocol-based VLAN.The following example adds MPLS to "my_filter":
configure protocol “my_filter” add etype 0x8847 configure protocol filter “my_filter” add etype 0x8847
The following example deletes MPLS from "my_other_filter":
configure protocol “my_other_filter” delete etype 0x8847 configure protocol filter “my_other_filter” delete etype 0x8847
The filter keyword and options were added in ExtremeXOS 15.5.
